Tuning Largest Carburettor
Phild76
St Helens
Hi, I'm converting my car slowly to a 595 replica, I've upgraded the piston and cylinder to the 70mm upgrade. The car is currently running a Weber 28imb, is it possible to put a larger carb on the car? If so what carburettor would recommend. Thanks
Model
Fiat 500
Year
1970
Mileage
In my opinion, the best carb that you can fit would be a "Dellorto 24/30 FZD". Sure, in Italy they are fitting BIG Weber and Dellorto 'twin-chokes', or motor-bike carbs (Kehin or Mikuni), but the problem in the UK is that very few people have the experience of putting these carbs on the 500/126 variants. The FZD Dellorto IS well known over here, is a simple carb (which has both a choke and an accelerator pump), is light enough that it doesn't need additional support, stays in tune, most of the parts are readily available still (if you know who to ask and where to go to) and all the jets can be changed whilst the carb is still bolted to the engine. They are quite expensive (as carbs go), but I think well worth it. I think that if you approach "Toshi", he has one of these carbs complete with its dedicated inlet manifold, for sale.
Hi Phil, I agree with Tom @ the hobbler re the Dellorto FZD But, if you need an alternative that is not that expensive look into the Weber 30 DGF. These are original fitment on the Panda 30 and 126 BIS IIRC. No need to adjust jets just bolt it on, it's a variable twin choke downdraught carb which gives good economy. The other carb that I have experience of is the Solex 32/35 PHH series, these twin choke side draught carbs are lightweight compared to the Weber DCOE series carbs and once you know what you are doing are straightforward to set up, parts/jets are available from Italy as they are original fitment on Lancia and Alfa cars.
Ian.
Thanks both, do these carbs fit the 499cc engine.. I see a lot on the 600cc engine but I want to try and get the maximum out the 500 engine if possible.. it's already made a big difference increasing the cylinder and pistons..
Whilst the Weber 30DGF and the Solex PHH carbs are good alternatives to the FZD, I think that as they were originally fitted on larger engines (both the Panda30 and 1/2 of the 1300 Lancia V4) are 650 engines. they MIGHT be a bit overpowering for a '595'. I would personally still look for a FZD, but of course, the choice is yours.
I have put a fiat Panda 30 on my tuned 650 and never looked back. You can feel at your pedal when the second chamber opens so you can choose for economy (easy 80km/h) or sport and to get that extra acceleration out. I even didn't had to replace any jets but put a wider intake hose and bigger filter in order to breath.
There's a graph in the Weber tuning manual that makes out that 26mm is the best sized carb for 500cc and 28mm is best for 600cc. By extrapolation, 29mm would be ideal for 650cc but 28mm is still well within their recommendations. Since you're running 540cc, a 26IMB or 28IMB would be ideal. What do you expect to gain from running a 30mm carb?
Abarth used a 29mm choke on the Solex 34 PBIC carb that they fitted on the 595SS, 695 and 695SS variants of the 500 (and I reason to believe that it was specially modified by Solex for them--up from 27mm choke on the 'normal' 34 PBIC). Abarth were well know for fitting BIG carbs on their engines, so I cannot see as to why one would want to go even bigger than the Abarth factory fitted. I stand by my recommendation of the 24/30 Dellort FZD for a '595'engine. I have just found that there is an Italian site that has just come back 'on-line' who has a selection of FZD carbs. If you contact me,I will happily pass on the company's details to you--- [email protected]
With respect to your information "Smart51" with regard to the Weber recommendations, the 500/126 engines don't rev nearly as highly as the most of the engines that Webers are fitted too, so one can get away with a slightly smaller choke size---again, hence my recommendation for the 24mm choked FZD.
Hi The Hobbler I've got hold of FZD carb a reconditioned one from Italy. Haven't fitted it yet, little job of winter that one as well abarth steering wheel and instrument cluster, appreciate everyone's advice
Well done Phild76. Just being nosey, where did you manage to obtain the carb from, and what size did you purchase? I live under an hour from you (Chester)---would it be of help to you if I came up to you, had a look over your carb and confirmed that it IS complete and all is good---from personal experience, not all the "reconditioned" carbs come from Italy fully complete! I have also fitted an "Abarth" style instrument cluster to my own 500, so I might be able to give you some guidance regarding fitting that as well. If you think that I can be of help, contact me [email protected]
Hi it was the FZD 24 30 I got it from lafo.it on eBay, see attached photo.. yes may be worth meeting up any help is always welcome being a complete novice
Looking at the picture, it does look complete, and it has come with a "gauzed" intake trumpet (now getting rare) and all the choke linkage. The inlet manifold with it is the older type, which in my opinion is the better version---the newer "machined-rather-than-cast" versions have a lot of sharp corners on the inside. Drop me an e-mail or give me a phone (01244-683824) and we can organise when I can come up to you.
I can see from your picture that you have bought one half of a twin carb set, the linkage is the give away. That is not a problem as long as you can work out the connections for the Fiat. In my experience those carbs were used on Innocenti Minis and you will need to replace the jets to suit the Fiat.
When I come up to see you (just let me know when you want that to happen) I will bring a set of jets that will be a good starting point, along with a pile of paper-work that will be of help to you. These are very easy carbs to work on---every jet can be removed with the carb still attached to the engine (with the engine in the car). From the picture I can see that when fitted to your engine, you will have the throttle linkage at the REAR of the car (front of the engine)---I also will have with me the necessary parts for connecting the carb to the factory throttle linkage on the top fan-cover---give me a shout
If you contact me directly "Phild76" either by phone or by e-mail (contact details in earlier exchanges), I have some pictures for you showing the best way to set-up your throttle linkage to the FZD
