Hi, I am a new member. I have a cheeky little Sei, Has anyone else had a problem with a lambda sensor heater? i think it is a wiring fault and just wondered if any of you had the same problem, thanks
Thanks for the welcome!! I got it plugged in at my mates garage, i can't remember the fault code but it said Lambda Sensor Heater Circuit, so i tried a different lambda sensor, and nothing happened so i assumed it is a wiring fault, which could possibly be difficult to track..
rough idle is normally sign of running rich probably down to lambda sensor.some have 2.i have spare brand new 4 wire universal one if you need it mate.
I have the same problem, after troubles with blocked catalyst converter and decat (https://www.fiatforum.com/cinquecen...gine-failure-blocked-catalytic-converter.html), engine control light is back on (lighten up while driving) and the same error-Lambda heater circuit..) - any idea which cable try to check???? and which lambda is wrong?? (mechanic said its the first/top one, then resets ecu and its fine for now again, so probably not faulty sensor)
..and are lambda sensors intercheangeable within SPI / MPI engines????
I changed the sensor which is before the Cat. (that is the only one) the light went out!! I was dead happy then later that day, on my way to work the bastard came back on.. until i get it checked i won't know if it is related..
