Knob Dilema
Knob Dilema
A
andy
HELP! I bought a momo gear knob but how do I get the original off? Assisstance will be rewarded with thanks!
PS Vauxhall are crap
ok
Hi mate, hows it goin. I will be doing the same with my new bravo soon and i asked the same advice.
A good lad called Roberto helped me out.
U will need most likely to saw it off.To do this saw in the middle of the top and go down far enough to then split it open and then to take it off.
If u log onto www.fiatforum.com and click on bravo styling, its there!
Allan Brown
Could be easier...
It seems, that on some models (don't ask me which ones) the knob is only fixed with a splint. To access it, simply remove the leather (or plastic) under your knob (its only fixed with the plastic of the middle console).
But it can be that not all Bravo models have fixed the knob like this. Just try, its not that much work. If there is no splint, then you can still use the saw to get it of.
Br
Powerhawk
Put the saw down!!
Why do you all wanna take a saw to your car?! I had the same problem when i came to put a Momo Alu Sport knob on. If you look at the Haynes manual it shows a fiat tech tool that they use to remove it, all it really is is a tool to provide a bit extra leverage, between the knob and the collar around the gear lever, this can be easily made using a couple of strips of metal and a couple of nuts and bolts. Takes 5 minutes at the most and causes no damage.
All this talk of knobs !!
Hi guys...
Thanx Alan....never been called a "good lad" b4 !! LOL :)
It does appear that FIAT changed the design of the knob from a "whacked on" version 2 a screwed version.
Like Alan said, I used a hacksaw 2 cut down the middle and prised it off within seconds. NO DAMAGE DONE ! :) (xcept 2 the old knob !!)
Ur then free 2 fit any knob u like.....here's a pic of mine....
Have fun,
Rob.
gearknob
i got mine off by twisting it to crack the seal and then basically pulling it off, which takes quite a lot of effort.
A
5
549
Shaun Cook
S
C
13
1K
Craig
C
L
248
L
7
225
mick calvert
M
