Technical Key code light remains on and car won't start
Jeffusa
Just fixed this problem on a Fiat Multipla JTD 2001
Using this link I changed a little red relay on the passenger side near feet.
(the forum won't let me post the useful url, wanted to give credit to the original poster, can probably google "key or immobilizer problem.txt")
Here is the original text just in case the link disappears
I am so happy that such a cheap solution worked that I have to share it!
Key/Immobiliser question...
The Problem...
My issue is that the car recently has some real hassles starting. Has been doing it a few months now, but seems to be getting worse. When turning the key, the orange 'code' light will either stay on (which I gather from reading other posts means that the immobiliser hasn't read the key code), or it won't light at all. When it does light, most of the time the little coil & injector lights DON'T light - and when this happens, the code light remains lit and then the immobiliser's active.
Workaround is to keep pulling the key out and turning again, and again, and again - and eventually the code, coil and injector lights will light up, and when this happens - the code light goes out. Following which there's about a 20 second delay before you can hear a quiet little relay click somewhere around the passenger side at the front, and then if you turn the key all the way, it'll start. If you try and start before this 'click', the engine will generally start, but then die. And then it's back to square one (although usually...the next turn of the key produces all 3 lights, so just another 20 sec wait).
So, I'm guessing it's either the battery in the key, or something more sinister. Problem is...when I got the car, I only got one key with it - and the key does not have a button for central locking or alarm. I just assumed it's not got remote central locking, so it's always key in the door to open. It's just a blue key, and it doesn't seem to be in two halves...by which I mean I can't see any 'line' around the middle where you could split it and change any battery in the thing.
The Answer...
Have sorted this issue out, and thought I'd tell the tale for the benefit of others.
Headline: If your JTD is playing funny buggers with the CODE light intermittently staying on, thus requiring much key turning back and forward before starting...and you KNOW that it's not:
A: Key battery
B: Aerial ring
then, before taking the offending Multi into a FIAT dealer for expensive diagnostic experimentation...spend 5 minutes to:
Try changing the red relay mounted behind the fuse immediately to the lower left of the (probably BOSCH) ECU up in the passenger footwell.
You'll need a deep 10mm socket to remove the nuts securing the protective plastic 'kickplate' covering all the plugs & wires at the bottom of the ECU too. That's all the tools you'll need! Just pull the relay out, put a new one in (or borrow one from somewhere else...there's at least 2 of the same relay up in the fusebox under the drivers oddments tray).
I'd had the car at an auto locksmith, who for a mere £10, tested the key and aerial ring without problem. He also plugged a diagnostic computer in and couldn't find any problems of note. I then spoke to a Fiat dealer, who advised it'd only be the key, aerial or the code-ECU, but they'd have to do diagnostics @ around £70 an hour! The locksmith had recommended as a last resort fitting a live 12v feed to the diesel pump to bypass the immobiliser with a switch in the car to control it! Didn't really fancy that, truthfully...
I then found Kings Lynn Auto Diagnostics, where a very friendly and helpful chap called Peter Remmington can reprogramme your ECU (if you send it to him) to remove the immobiliser completely...a 'freerunning' ECU. (Clearly, implications for insurance if the Multi's nicked, but I figure they're not a joyrider favourite..)
I'd seriously recommend this guy if the relay fix doesn't work, you don't want to pay big money to Fiat for a new CODE system, and you're prepared to risk the insurance issues. Just google him, or 'multipla freerunning ECU'. He can do the JTD Bosch ECUs.
So, that's what I was about to do, basically. Then, in process of removing my ECU - knocked that relay out, and wondered...
Swapped it for one up in the fusebox, reconnected car battery, and hey presto - CODE / Injector / Coil lights on and off, car starts first time, repeatedly.
Very, very chuffed.
Hope this might help someone else in future!
Dave
WELL DONE!
I've had this problem although it went away on it's own and others have posted with this problem without getting a solution.
Surprised Fiat aren't aware of this as I'm sure it must have come to their attention by now?
Brilliant ! I went to Fiat to book the car in having resigned myself to the fact that the problem was beyond an easy solution ,but they were booked out, went home ,found the forum and the solution to my problem (EXACTLY as described in the post- I'd been putting up with it for 6 months and it recently got worse with the cold weather) ,went to the parts store and fixed the problem for 2.40 euros.
Many thanks.
Mine does this some days and not others. Yesterday, in fact, it needed a cup of tea and a sit down to get it going (no problem since)
Ill take a look. thanks for the info
Sorry to come back to an old thread but, when you say that the red relay is in the passenger footwell, do you mean in the box with the other relays (red and black) and fuses in the engine compartment?
All the best,
Mike
A big shout out for Mark at Car Hacks 07449467554 Crawley. I have no links
Bought 2010 Multipla not running as ECU immobiliser issue and took a punt ... more later.
Car had not run for 8 months and seller gave up having had various people look at it. (Autotronics in Leicester had his ECU for 4 months)
Found Mark as he offers ECU/transponder and key set (and mapping etc) on ebay and then found out about his Multipla tendancies.
He has run Multiplas for over 10 years as service vehicles !
He agreed to meet me at the vehicle.
Any way after a few hours of moving in and out known working components and various voodoo - Mark said issue was power to ECU not any of the components. He could not get comms with the ECU. We did not have any pin outs for the ECU or wiring details. He could not take it to Crawley as it was not taxed and tested, so I winched he on the trailer and she came North.
07:30 next morning changed the red relay in the engine bay with orange wire and she ran. :D:D:D:D:D
(based on info from this forum)
My 2000 petrol bug cut out while I was driving today, RAC chap couldn't get comms with his laptop/plug in gadget. No feed to ECU or fuel pump.Sounds like he same fault, his computer brought up a previous example of car not starting because of the relay fault.
Have just ordered one from ebay, fingers crossed that it works.
Could be camshaft sensor, they stop the diesels when they get warm sometimes and fail they used to be about £30? Good luck.
On MK1 red relay is inside I think under the plastic thing in the middle?
I've had a look in the passenger foot well, nothing that looks like an ecu, no red relay. By the 'plastic thing in the middle' do you mean the moulding that separates the two footwells, ie under the radio and ashtray down to the floor ?
I've having a similar problem with my CODE light flickering. I managed to start the car using a workaround protocol with the accelerator pedal but would like to fix the problem, hopefully without a new ECU. Where is the red relay in the passenger foot well? There is a cover plate to the left and the floor cover separating the driver and passenger. If someone could point me in the right direction would be appreciated.
At the top of the post they talk about it. Different on old and new shapes.
On mk1 feeling the middle floor thing but there was also an ECU to left of footwell on passenger side ...
My fault was on MK2 and that is in engine bay near battery in 6 by 2 inch plastic box.
