Just ordered this!!
Just ordered this!!
100% correct!!!!
All you have to do is run a new power cable direct from the battery and a new ground.
The new power is due to the power that the head unit uses as many of you have said. The new ground is becuase the thickness of the power wire has to be the same or greater than the power cable in case there is a surge. In which case the original ground would have melted.
And yes 50w x 4 head units are unlikey to require direct power feeds, as a basic rule direct feeds are required for 60w per channel + head units.
Hope this helps. Dan
bloomfieldliam said:
It came today, requires some extra wiring due to te 4x60 internal amp so it won't be fitted till later.
Didn't know it came with remote though, very cool but not much use in a Cento though!
I'll give it to passengers to play with.
Liam
If you've got space on the plastic cover that runs down behind the handbrake, you could mount the remote there so that the people in the back could turn the volume up if they so desire. I would mount it on some velcro just in case you want to move it around.......
