core plugs should be in stock, T.I.S. by the way is technical disc that ford use...loads copies to download on peer to peer sites
sorted??
good stuff.....it'll be fine.
just used google and now see what the core plug is
will get the cover off give it clean and see what is going on and if there is any trace of coolant in the area of the core plugs
ordered the Plugs today should be here monday
Had the cover off today and it was snuff dry no trace of coolant round the plugs just a bit of muck and grit and a bit of moisture on the top of the cover...
so cleaned it all out with a stiff paint brush and hoover followed with a paint brush full of cleaning solvent (IPA) and hoover again got most of the rust off
this was taken after a quick hoover to remove the thickest never got round to taking an after shot :bang: but its all nice and clean
then removed and cleaned the Spark plugs and HT leads filled the cap with silicone grease
so am going to pick the plugs up this week and give it a few weeks to see if there is any trace of coolant leaking from the plugs
I did clean the engine bay about a month ago (low pressure free running hose)so that might have been a source of water ingress
but i'll wait and see how this goes
Thanks again T![]()
