siwilks200
- Joined
- Sep 17, 2015
- Messages
- 95
- Points
- 27
Hi all
I changed the EGR valve (Inc the lower pipe) because it was stuck or the electrics had gone. This fixed a big acceleration/maf sensor warning I had.
Afterwards i noticed that whilst accelerating it stutters and at the same time it releases a hiss and I lose power when it stutters. It eventuality picks up though.
Months later i took the idle control valve off and cleaned it all as well as the egr from build up and oil. No fix.
Weeks later i see a lot of oil around the idle control valve and mostly around the small black plastic actuator that controls the valve. It looks like a oil is spraying out around the whole area. Probably I made the seal worse this time.
My question is does this sound like a leak and is there meant to be a gasket in between where the black air hose connects to the idle control valve because I don't have one. But there is a metal gasket between the idle control valve and the head.
Is the hiss the egr valve working. It has been said that sounds like the turbo working.
A nice image breakdown of this area would be useful to see the gasket positions. Thanks
