cipher
Hello,
In addition to the ball joint issues that we have with our Ulysse, it has now developed another problem.
The car will start and run fine, but when accelerating, there is a noise from the engine. It is not related to engine speed, more engine load;
When you accelerate the noise is there, but when you lift off, it goes, although the engine revs are still up, the noise will go until you next apply the throttle.
So I am thinking either an air leak, or a blown/worn turbo.
I am more inclined to think the turbo is on its way out, as the pipe to the inlet from the turbo has oil in it. There is also some blue smoke when the engine is revved.
I would of liked to of taken it out on a test drive today, but I am waiting on parts to finish the wishbone. (New rear mounting bolts and a new clamp for the anti roll bar bush).
So if it is the turbo, what type is it, and can I use one from another 2.0 HDi (406, Expert etc etc.) or are they specific to the Ulysse JTD?
Many thanks..
Many thanks..
