Hi folks. I suspect i may have a leaking water pump. as i cant see any leaks, but am loosing water. Engine running fine and no evidence in the oil system of gasket failure. The yellow warning light imediately under the temp gauge flickers on every now and again, even after header tank filled up. I'm guessing this is some warning system icon for the collant system but cant see it mentioned in the car manual ! Can anyone tell me also if the water pump is driven off the cam belt, or "fan" belt.? ie if the pump disintegrates it wont kill the engine ! also can i get a manual for this engine?. Mine is in a marea 1.9jtd, 01 plate. thanks for any help as allways.
