JohnDragonMan's Dispatch/Scudo Micro Camper Conversion
Hey everyone.
Well a year or so ago my brother and i had the idea to get a van to convert into a camper. so we bought an Iveco Daily mk4 (2008). this was a refrigeration van. when we took apart the back of the van it had rather nice 50mm XPS insulation that we ended up recycling with much spare left over.
cut to a few months back, we still have the Daily which is still in the conversion stage but im enjoying it that much i want my own van. so i start looking at small vans. i originally was looking for a Doblo XL but i wanted something a little older, without advanced ECUs and emission controls. i went looking on Gumtree and saw this van for sale very cheap. i decided to go and have a look.
he told me it was being sold with faults. somehow over night it was draining its battery, and it over time started lacking in power. the chap had it in to a garage and they told him that it needs a complete new ECU to fix it. he was retiring from his self employed gardening business so the van was not needed as much as it used to be. fearing the cost of a replacement ECU and other faults that needed fixing he decided to sell it.
he also told me that he had the van a good 10 years or so and he religiously serviced it each year even if it did not clock up the required service mileage. on checking the dip stick i have never seen an engine so clean internally. not one bit of tarnish and the oil still a nice pleasant honey colour. little to no blow by and no noticeable oil leaks. Very Impressive.
on that i bought it.
i now was the registered keeper of a 2005 Dispatch "Enterprise 900" HDI with 99k miles on the clock for £325 with 12 months MOT.
my plans:
first off i wanted to install 2 extra seats to the van to make it a 5 seater. (more on that later!)
now i have some interesting wild Insane plans for this van. i love electronics. i cant help myself. so heres a little list of what i plan:
i plan to cram in a 48v leisure system to this van. the main component will be a heavily modified hacked and slashed 48v backup UPS (an APC SRT3000RMXLI)which will pretty much do everything for me. already having a mains charger built in, it also has a built in inverter at 2.7kw and being a UPS, if the electric hookup power fails, it will instantly switch over to battery power and keep all my 240v stuff working.
i will be using a "wind turbine" controller that i will use to tap directly into the alternators 3 phases to charge the 48v battery bank which i plan to store under the van in the gap the spare wheel usually hangs. ill be using gell cell / SLA, but if i can get my hands on some tasty AGM batteries i will use those.
the solar photovoltaic array i plan to have is also going to be pretty insane:
i plan to have a lot of solar power. i will be using a full sized roof rack on this van (that i may extend a little over the windscreen), and on that i plan to have a large roof box for storage (maybe 2) and maybe the spare wheel (though i may mount that to one of the rear doors). i plan on covering the roofbox(es) with semi-flexible solar panels. ive calculated that i should easy get 5x 18v 30 watt panels per roof box. each roof boxes solar panels will be linked in series so should get a nice 90 volts. if i do get another roof box i will add it in parallel to give my twice the amps output. i will then feed it into a Victron solar charger.
if that was not enough!
i will also have large pull out solar panels. these will be dual use. not only will they be able to be pulled out from under the roof rack for extra power, but they will also double up as a rain cover above the doors. i even have the plan on making them "push button deploy and retractable" using DC actuators. this however is something to do at my leisure as its more for "showing off"
im unsure of the total amount of watts all the panels combined will give but when the van is parked up at home it will be fed into our home self built solar array and power the house.
it does not end here however.
the van will also have a pressurised water system using a pump and bladder tank, both hot and cold running water. i will be using an old office drink water dispenser for the heating system. which has 2 modes, a 300w "instant heat" mode and a 30w "keep hot" mode where it stores water at a constant 60.c to 90.c (adjustable)
and lastly. yes there's more
i also plan to build my own refrigeration system in the van to run a fridge freezer. it will purely be a 48v system. the compressor and condenser (radiator on the back of a fridge) will be under the van (for noise and the coldest place giving the maximum efficiency) also saving internal space. ill be using a pre-built fridge i think. though not very well insulated (to my standards anyway) it will just make things easy.
i also plan on having a microwave grill too. that will be ran from the UPS inverter. should just about manage.
hacked and slashed ;)
now that's out the way, here is what i have done so far:
the evening i got it home i was sat in the van for a while reading through the booklets and various paperwork when i started hearing a buzzing/clicking sound. i traced the noise back to the rear left of the van, behind the lights. turns out the tow bar had an auto voltage detector for charging a caravans battery. this was looking pretty rough and quite melted to look at. i left it in place but pulled out the fuse. over the next 2 months i can report that the battery has never gone flat yet i have never really driven or even started the van up! will be an easy fix!
my first priority when i got the van home was to change the cam belt. 99k miles and a 15 year old cam belt is not odds that i like to play with. turns out its a really easy job on these vans. i locked the cam but never bothered locking the crank as i just used the visual timing mark to line it up. i replaced the water pump, tensioner and idler.i used a Gates timing belt kit. (we all know that they are the best!)
i also noticed that the throttle cable was very slack so "pegged" that back up a few notches. :) sadly this did not fix the engine power issue.
i also noticed that it had replacement discs and pads too! :D
now that was done i set about taking all of the original plywood out of the back. all in fantastic condition, all i planned to reuse again.
after cleaning the whole of the inside of the van with meths, my next priority was to install the extra 2 seats to the back. i wanted these seats totally removable as i still wanted to use it as a "lite van". my issue was that i wanted to have seats that could fold flat so i could lay a bed over the top of them. i also wanted them to have built in seat belts. all of which are quite rare things. i went into massive research looking for vehicles that have fold flat removable seats with built in seat belts. i eventually found out that Ford Transit Tourneo custom vans made after 2010 had just them! after contacting a few people i managed to buy two seats.
the seats fit perfectly in the original van floors "corrugation".
i welded in rather thick plate under the floor onto the chassis of the van so i had some very substantial seat mounting points. this did involve taking the fuel tank off in which i took advantage of the situation and repaired the very rusted fuel tank brace support, undersealed and rust proofed all chassis box sections using Dynax S50.
i bolted the seat runners in and installed the seats to test them before building the floor and its insulation.
i then set to insulating the back of the van. remember that 50mm XPS insulation i had left over? we that is what i used! this got used on the roof and the sides of the van. it fits perfectly depth wise.
i used expanding insulation foam (not the normal builders expanding foam) to hold the XPS in place. it also filled any missed cavities in the insulation due to my bad cutting skills.
for the floor i used 25mm square wooden batons and 25mm Celotex. then laid the original plywood flooring over the top of it all after cleaning and cutting out the holes for the now fitted rear seat mounting points.
i also insulated inside the steel cavities using polyester "teddy bear" stuffing as it does not hold moisture and remains breathable.
After all that was done i "sealed" everything in with thin plastic sheeting as a vapour barrier using aluminium tape to cover all of the holes into the cavities. (i also dynaxed some of the cavities, just for rust precaution)
i then covered all of the steelwork with 6mm closed cell foil lined foam. to give it a "warm/soft" touch then covered it all with Auto Carpet. no cold hard steelwork to touch in the middle of the night!
i did the same with the original plywood side panels after cleaning them and cutting them down to size to lay on top of the insulation vapour barrier.
i went for a dark grey auto carpet for all metal covering and a cream auto carpet to cover the plywood side panels. i will be using black auto carpet around the bottom of the "walls" of the living space. about 20cm from the floor up. i will disguise the colour change line using a thin strip of "ornate" aluminium checker plate.
i started work on a bulkhead with a plan to make a sizeable over head cupboard. before that i took out the old headlining, sound proofed and insulated the aerial with dense sound deadening sheeting and 10mm closed cell foam.
while i was under the van i had a poke around at the rust and made quite a "holy mess"... holy sh!t. well i can weld it all up but having done that much of it i am at the point where i just do not want to do that kind of thing anymore. i ordered new sills and planned to take it to a body shop to repair as they would make a much neat job of it than i would.
i planned to leave the roof with some plywood over it and then stain it a darker colour. however i am unsure with this idea and may change it.
from the photos you will notice that the van has a spinning roof vent. i have great plans for this. swapping out the vent for a low profile one so i can still fit my roof rack on. i plan to use it as an air intake system. now i suffer greatly with hay fever. so i will be building into the roof a HEPA air filtration system and aircraft style air vents. i am the kind of person that likes to sleep with the noise and feel of a fan blowing on me (i am really very highly strange). this in the summer months will be quite nice.
i have recently fitted a 2kw diesel air heater under the passenger seat. having cut out the "storage basket" to make way for it. i had to hammer flat some of the vans floor corrugation so it fit in nice and level. i did this using a trolley jack and a brick so i could hammer flat without concaving it. it fits in the gap really well but is close to fuel and brake lines under the van. i plan to make a heat shield for them. can never be too cautious. the heat output should blow nicely down the central walkway. between the seats and the kitchen units.
ok so as of today i have had the van for about 2 months and finally insured and taxed it. its insured as a camper in the conversion stage but still has SDPC specs so i can drive it to work :D
so far i have not looked into fixing the engine power issue. i took it out for my first drive in it and i was a little worried about it being as slow as it was. thankfully i know a thing or two about modernish diesel engines so i started to unplug sensors. well first sensor to unplug was the Mass Air Flow sensor (just behind the air filter box). low and behold it was like i hit LAUNCH on Saturn 5 rocket. that was easy. too easy. well i have ordered a replacement MAF sensor and a replacement inter cooler. i will fit them when they get here.
That is as far as i have got! on Friday i will be taking it into the body shop for the welding work to be done. the body shop specialises in repairing E7 Eurotaxis so no stranger to these vans. they also have many scrap taxis around the back. i may even buy all the bits to retrofit air conditioning to my van from them! just for the filtered air mainly!
thanks for looking! i will be sure to add more updates as it progresses.
just to note, i am keeping Vlogs on this hosted on Youtube.
see the playlist here:
https://www.youtube.com/playlist?list=PLq_C4DcbSFgILFitaYNBnZSO2ISNI3vhn
-JohnDragonMan
yes a few times! nothing is built in the back as i am still using it as a van.. all be it insulated and carpeted. well all but the doors which i need to do. i am currently working on the leisure system as i have opted for a 24v setup. 2x 100Ah large flat plate gel cells fit perfectly under the middle seat... with some modification but they fit! just waiting on some things to come through the post.
im actually going camping in it in the next few days :D
Ok so i have managed to fit the 2 gel cells under the seat! i did have to do a little cutting but they went under and fit quite snug.
heres a photo of just one fitted for now:
full
note the little bit of metal on top of the blue battery, that is the bit i had to cut off the drivers side seat. its the mounting point for the middle seat's seat belt clip. as you can see, i cut it off and relocated the mounting point for it behind the seat. seems a bit more strong being mounted there now. it also lowers it slightly as it used to stick up quite high and now it sits just above the drivers seat belt clip.
the 12v to 24v charging system is almost wired in i am just waiting on the large 350 Amp Anderson connectors to get here. they will not only be one of my isolation points, but they will also be needed to be so big to handle very high current loads if i ever use them to jump start anything... which i do plan on mounting 2 pairs of Anderson connectors under my tow hitch. one for 12v and one for 24v jump lead connection points.
i have just installed 2x fuse boxes one for 12v and one for 24v. i need to make labels and im considering setting up a colour scheme to differentiate between 12v wires and 24v wires. just a wrap of coloured tape or something.
hmm i do need to add a small switched live fuse box too.. maybe.. hmm nahh i can do that on the relay sense side of things.
all exciting stuff.. took me a while to get around to it but its happening!
Ok so side project.. Cruise control. i want it and hopefully going to hack and slash it to my van
so i am hoping this is going to be a little "how too" tutorial.
i have all the plugs and wiring necessary for this!
there should be switch that "turns on" the cruise control. its a connector with 4 wires. 2x wires are for the switch and 2x wires are for the LED which tells you when its active (i think will update)
any switch and a notification panel indicator would suffice. you can get the original switch but its costly just for a switch (part number Fiat: 1471957699, Citroen/Peugeot: 6552 PQ)
now for the foot brake switch.. easy! just modify a brake light switch from a scrap yard, fit it, and plug it in! you have to file down the little bump on it, then it plugs right on in. you can still buy this if you want but again costly (part number Fiat: 9606177280, Citroen/Peugeot: 4534 26)
now for the column speed switch lever stalk thingy.. oh boy.. this .. you cant get this anywhere. well the odd seller on some European ebay shop may have one but expect three figure numbers! (part number Fiat: 9627551769, Citroen/Peugeot: 6239 g9)
or.. theres my option..
just modify the radio control stalk from a mk1 Peugeot 206cc.. as its THE SAME stalk. seriously. identical. (part number 96373745zl) .. with one exception.. it only has 2 wires. where as the one we need has 5 wires.
now hold on. if i know a thing about vehicle radios.. and i do.. that 206 radio control stalk will have 4 buttons. just like the cruise control stalk. only the 206 being for a radio will be "resistive" meaning each switch makes a different resistance the radio sees.
well we're not interested in the resistors but if i can tap directly into the switches.. hmm 4 buttons.. 1 common wire going to all switches.. and 1 wire coming out of all switches.. equals 5 wires! well that was easy! getting them in the right order will be fun but i can do that by jacking up the front and "driving" the van with the wheels moving in free space to see what each wire/pin on the vans speed control column switch plug does. my guess is on/off speed up/down. i don't have a manual to hand so cant confirm that.
given what we now know.. umm assume.. that should be working cruise control. as far as i know there's no software lock out in the ECU.. why would there be? i mean it was usually an optional extra fitted at the dealership.
so i guess ill report back a little later on. i will naturally edit this post as and when i figure out new info... and add photos. i have a few already but they are not my photos to upload here.
  • Like
Reactions: ben
Ok my "radio" control stalk came through the post.. yeah i know.. on a sunday?!
sure enough it was 2 wires.. soon managed to pop the 4 clips holding it together off and have a look inside
label from the radio control stalk (note L33t image editing skillz0r):
well as my suspicions were true. resistive!
after a quick study of how it works i plugged the soldering iron in and set to modifying it
note i cut the original track on the left of the last picture. ^
here it all is as a kinda real life exploded diagram:
and the final product:
well its a shame im at work tomorrow but i may have a go at stripping the steering wheel column plastics off on my lunch break.
i have already fitted the extra brake pedal switch (literally did that in the first few weeks of having the van lmao) so all i have to do is fit the "on off" (with notifcation LED) switch and try to make it look good.. no hacked/slashed plastics
well stay tuned.
well my aircon has failed.. the system has no pressure. i suspect the flexible hoses have gone porous. that assumption has been backed up by the fact that halfords "top up" bottles contain a UV dye.. and when shining a uv torch in the engine bay, the aircon hoses light up like a florescent tube.
hmm i am highly tempted to remake all of the flexible pipes out of copper. i know the rubber seals are good as i replaced them all, even the main shaft seal in the compressor.
on another note i have finally managed to acquire the very hard to get pollen filter housings! my local pick and pull scrap yard had a Peugeot 806 in. the engine was removed sadly but the scuttle panel was still intact along with the prize hidden underneath.
i instantly fit them to my van when i got back. heres the photos:
And the all important part numbers!!!
i hope with this, if you are looking for such things you can find them with this info.
  • Like
Reactions: ben
well its been some time since i updated this.. so to cut a long story short i have not used my van for over 1 and a half years now. its just been sat on the drive. so i think its time i sell it. i however first need to repair it. the reason why i have not used it is because the alternator died on it. i did suspect it to have issues as the voltage was unstable, it never made a constant fixed voltage. i should have changed it when i did the work to it but back then i didnt really know! about a year ago i replaced the alternator with a new one which didnt work. this was because the van uses some funky charge system not a nice simple resistive load to excite the windings to start it charging. so i now have to take that alternator off and replace it with the other alternator. sigh,
well ill set about it when i get it. the next task after will be an MOT. then i will advertise it as a half complete camper project.
the van is i would bet the most rust free van in the UK and i would go as far as to say that it wont rust for many many years with all the rust proofing i have done to it. i totally stripped the underside of all suspension components,cleaned everything and repainted and undersealed the lot. even used lots of cavity rust proofing and made sure to get everywhere inside. i retrofitted air conditioning, and gave it the bi-xenon projector lens headlights which is such an improvement over the originals. it has the most expensive tyres i could buy at the time and has had all of the brakes fully serviced along with a new cam belt a few years ago and a new clutch which is insanely light. more light than Talons! the engine was never played with power wise, it was always enough for me, but i did take off the intake manifold, turbo and EGR to clean it out along with the ports and valve tops. so the intake system is very clean... and will remain clean if you get what i mean.
i would like to think that i would get above the average asking price for it with the work i have done. basically a full underside rebuild.
the van should last years and years. heh if anyone on here is interested in it, let me know! id love it to remain on the forum!
check out my youtube channel playlist of all the work i have done to it as it was all logged:
i have other projects, another van and even a lorry that i really need to divide my time over.. and as always my biggest curse is not having the drive space to do the work on! so i hope selling this will make a little room for them. maybe first however the panda that @Bougainvillea Rosso gifted me... i really need to get that on a driveway and welded up. thankfully i have all the replacement glass and interior for it still before it all got rained on. ive never had a 2wd panda before (besides one my dad drove around 1999 that i was too young to drive) id like to see how they feel to a 4x4 :D
well i may add more to this.
