I've been informed this is a Fiat engine in this vehicle,...............
Peugeot Bipper van 1.3hdi 63 plate.
The problem i have is as follows,... Starts fine from cold. Once warmed up does not want to fire up and run.
It starts a-ok first thing, from cold, but if i run it and get the engine warm then turn off and leave for 5 - 10 min's, return and try to start it, it won't fire up Turns over fine and the starter motor is good.
I've recently had a brand new timing chain kit fitted, by a reputable garage and i 've also had a new cam sensor and 1 glow plug fitted. I had a injector leak off test done, that showed 3 poor injector's, and so i have had all 4 replaced with reconditioned injectors, I was hoping this would solve the problem but it has'nt.
If anyone could offer any advice it would be much appreciated. Joe
