it dies. than it shows "key code"
our punto sometimes dies during driving. it always happens in low gears (3rd max.). when the engine dies, battery and oil warning light comes on.
than i restart the engine with no problem but orange "key code" light stays on. on the next start up it is like nothing happened till next "blackout". the mechanic said the battery is a bit weak already. it happenes quite often like every 2days. i'm driving with spare key and don't know, if the problem is present with main key also. can mentioned problem be in connection with the battery or what?? what's minimum voltage for the battery? have multimeter so i can check it
punto mk2
punto mk2
