Have you connected up the Speed sensor wire on the Pioneer? If not is it working ok without?
I'm fitting one in a Ducato and I will have all the issues you have had so thanks for doing my homework
Pete
Yeah it works fine without it.
The speed sensors only true benefit is if you go under a tunnel. When you loose satellites it uses your speed to calculate and give your position within the tunnel.
If the speed sensor isn't attached it simply uses the last speed of your car as you lost satellites to calculate your position. Now I've never had a problem with it. Within a tunnel your speed never alters that drastically so it manages to calculate your position to within a couple of meters anyway. Even if your forced to slow or stop in a tunnel etc with traffic you can't exactly get lost. You can only go one way.... out. And within a second or two of coming out of the tunnel it has found satellites again and carried on from where it left of.
