ISO connector
ISO connector
Datsik
Derbyshire
Hi
I'm trying to fit my kenwood KDC W6541U stereo to my multijet grande punto but i have a problem finding the correct iso connector. i bought the PC2-86-4 as many people suggest but as you can see from the picture that is completely different to what i have in my car, i went to halfords which said it is a possibility of 2...tryed them both and none of them had the correct pin placement ether.
If any one could identify which one i would need that would be great
thanks
Halfords are useless tbh, when I did the stereo in my other half's Grande (also a Kenwood, luckily!) we got the Connects2 adaptor harness along with the Kenwood patch lead, so not only was everything powered correctly but you can also continue to use your steering wheel volume/track controls. The Autoleads version didn't work at all so avoid.
Hope that helps.
Edit: This ebay auction is for both items, just make sure when you buy it you specify to the seller that you need the lead for the Kenwood.
perfect as i was just about to buy the steering control adapter also, emailed the seller just to double check its has the correct pin placement as the pics on the internet don't appear to be for mine but hopefully should be fine.
thank you very much :D
i bought the connector you linked and it din't fit at all, every wire and pin was completely different. i can't believe how hard it is to find the correct one :bang:
