Is this amp alright?
peaky93
Thinking of installing these in to my Fiat Punto 1.4 litre 2003
1) Auna Car Speaker Pair 5“/13cm Black (front doors)
Max power: 500W
RMS power: 2 x 120 W
2) Mutant 3-Way 6" x 9"
Max power: 300W
RMS power: 150W
3) Edge ED612 Active - 12'' Active Enclosed Subwoofer
Max power: 900W
RMS power: 300W
My question therefore is, is this amplifier a good choice for this install and would you recommend I hook up the sub by itself, or the entire install? (I'm a newbie to car tech btw if you hand't already realised :p)
This is the amp:
COUGAR 3000W 6/5/4/2 CHANNEL CAR HIFI AMPLIFIER MOSFET
If you type that in to Ebay, you will see it however i will list the spec here:
6 channel Mosfet Power Amplifier
Powerful 3000 Watt Max at 4 Ohm
4 x 500 watt + 1 x 1000 watt = 5 channels
6/5/4/3 Channel operation
Bridgeable
Many thanks in advance for any replies!
i have the same amp please can you recommend between £100 and £150 worth of speakers this is my first system so not too hard to wire or high in price plz. can you also supply lonks if possible thank you.
Signal/Noise Ratio: 74 dB (unfiltered) Amplifier Type: Multi-Channel
Number of Channels: 6-Channel RMS Power: 3000 Watt Max at 4 Ohm
Type: Multi Channel Amps
