That's the kind of money I'd expect from a Garage -
fully valleted, and with a long guarantee.
On the plus side with one of that age you have servo brakes, possibly the later (manual) gearbox -
Plus, a good Panda is fun to drive.
A bit noisey and a bit bouncy, but quite nippy.
You can get through small gaps in traffic, park in small spaces because you can see all the corners, and put
very large objects inside it.
It's cheap to insure, and should do anywhere between 40 and 60 to the gallon, depending on use and how heavy your feet are.
Minus is the engine management, and the catalyser in the exhaust.
It's nice when the engine management works OK - no messing about with a manual choke - but the individual parts are relatively expensive (compared to a few hundred for the car) and then there's labour charges. Unless you sort it yourself.
Don't consider the auto.
Finally
Don't crash into a modern car....
