Fiat 500 lounge (1.2, dualogic) 61 plate automatic transmission (based in the UK, if that's helpful).
Hey guys, I got my car second hand about half a year ago - it definitely has a fault which I know is an issue, but proving it is a bit difficult because it's hard to replicate (has kicked itself into neutral whilst driving along, which after research seems somewhat common). There are some things I wanted check whether it was normal for this make and model of car, or if there is also a problem! I have a warranty on the car, so I can take it for repairs/investigating if I know these aren't actually normal. So:
When swithed off, manufactuer reccomends to leave in gear, which i do (if i leave the stick in neutral it beeps at me when i turn the car off). When turned back on the car is back in neutral (gear stick still in gear) and beeps at me until i move the gear stick back to neutral then back to in gear. This happens whether the the car has been off for 5 seconds or overnight.
Won't heat up unless it has been driving for 10 minutes. Even if it has already been on for 15 minutes whilst I'm trying to defrost/demist the windows.
Have to do hill/handbrake starts on the tiniest of inclines, like if I have to stop half over a speed bump I will have to handbrake start to make it over otherwise its rolling backwards.
Doesn't move forward when taking foot off the brake, stays in the same spot unless on an incline/decline. Its the only (automatic) car I've driven that doesn't start moving when you take the foot off the brake even a tiny bit.
It can be jittery when going at slow speeds, like when creeping forward in traffic.
Oh, it will also slightly struggle if it's on the cusp on changing gears and I slow down, then speed back up a little bit. The RPM will be quite high and it won't drop the gear straight away.
Thanks in advance!
Thanks in advance!
