No, apparently.
SPD
yes it is i cant spell
and its more than likely gone due improper antifreze mix and water has eaten aluminum
No, apparently.
SPD
Fiat head gaskets are poor quality.
Found rust spots and pitting on gaskets from engines with between 28k and 48k, So, It starts early.
So even if it sounds like the one mentioned above
Why would it be bad one day and ok the next?
Could be something else, but a compression test will be the best start to a diagnosis.
Lastly if you live in a hard water area such that kettles need descaling at all, then you should use soft water or distilled water or demineralised water in coolant mixed with the correct ratio of antifreeze.
Other wise the cylinder head will cover itself with calcium carbonate insulator and run a little hotter.
Dont worry about your english either I learnt all my spanish from US films.
Noel
