Is ‘Economy Driving’ Worth It?
Perhaps in your country, but not in the UK.The other issue of course are those with manuals and most do not know when to shift up or down.
He lost me @
Doesn't the ignition advance as RPM increase ?
Driving at low rpm causes more soot
And
Low rpm causes the engine to over heat
The facts in the video are flawedhis message was…Ask yourself: will the cost of repairs (engine stresses of consistent ‘labouring’ at low rpm causing premature mechanical component failure) outweigh the fuel savings of ‘eco’ driving?
Also (not covered here) is the matter of safe driving i.e. being in the right gear at the right time - what I (and I guess many here) were taught when we learned to drive, and were expected to demonstrate in the dreaded driving test![]()
That's all a bit "from a certain point of view".Low revs don't overheat an engine
Less explosions per second, equals less heat to get ride of
Water pumps are designed to work from idle
Oil pumps are designed to work from idle,
Low revs doesn't build up carbon then mixture is controlled by the O2 sensor
Burning oil, rich mixture, does, but an engine running correctly, makes no difference, especially on modern fuels
The Italian tune up to remove carbon on these engines just isn't true, the exhaust valve is always too hot, when you strip the head down it will just have ash over it, it's impossible to get the inlet valve hot as it's constantly having cold fuel sprayed over it, accelerating hard put more blowby back into the combustion chamber, increasing build up, even at a steady 5K RPM the outer edge of the piston closest to the water jacket isn't anywhere near hot enough to burn carbon off
Low revs don't put more wear on the connecting rods
The highest cylinder pressure is at maximum torque, that when the maximum push down occurs
The only time low revs will damage an engine is if it's designed wrong or there's already a problem,
A DMF may have a harder time at low rev
I AGREE.My first contact with this idea was a Toyota Aygo 1.0 hire car that kept suggesting I should change up a gear when climbing a hill in third.
It's obviously nonsense in my opinion.
My sister on the other hand is a convert to this philosophy.
I've given up trying to reason with her and grit my teeth as she tries to drag her Hyundai i10 up a hill in fifth gear on full throttle, holding up HGVs.
I like the cycling analogy, I've used it before. It's much better to choose a low gear and keep spinning
I do think the "eco" button you find on cars is just for those that cant drive economically, and it effectly just desensitises the accelerator pedel.
I've only used ECO in twinairs, not got it on the 500 FIREBut for the actual driving, I've often wondered if it's more economical to accelerate hard up to say 60mph, or slowly accelerate in a higher gear. The engine is probably more efficient pushing harder (less relative residual losses), and this would be for a far short period then the longer acceleration.
It's not from a certain point of viewThat's all a bit "from a certain point of view".
They are all equally designed to run at higher revs too, without overheating.
And maybe it's the type of car, but I've often found cars do run better and happier if used properly (not for economy).
Maximum torque is often at lower revs, so things will be stressed more there.
DMFs have no place in any car, so I view them as a design flaw.
Just as a slight aside, the satnav on the hybrid juke had a new option I'd never seen before. You had the usual fastest, shortest, but now it has the most economical. Which was different to the other, and seemed to go through the town. I'm guessing they take account of running on electric for this, and town driving is very economical if the engine isn't running.
Neither does high revs. The only thing that should overheat an engine is a coolant leak, or possible running lean.Low revs don't overheat an engine
Questionable, you will have more fuel and air in there to make up for the lack of revs, meaning fewer but bigger explosions.Less explosions per second, equals less heat to get ride of
At idle there is also far less work for the cooling system to do. But a bit irrelevant as the thermostat controls the cooling, not the waterpump.Water pumps are designed to work from idle
If you've ever seen an oil pressure gauge, then the pressure at idle on a hot engine is normally 1 bar or less. Usually the pressure reg controls it at not much above idle. But just because it works, doesn't mean it could be sufficient when the engine it delivering power.Oil pumps are designed to work from idle,
Questionable for same reasons above, same power means more torque, means more force on the rods and lower oil pressure.Low revs don't put more wear on the connecting rods
The reality it's far more complex, you are more likely to have higher pressures at low revs since the volumetric efficiency drops as the revs increase (you just cant get the air in quickly enough)The highest cylinder pressure is at maximum torque, that when the maximum push down occurs
Again, depends on the engine, modern diesels will die if you only run them at low revs. And I always find petrol engines (not modern eco friendly ones) run better long term when given a bit of abuse.The only time low revs will damage an engine is if it's designed wrong or there's already a problem,
Correct but the video says low rpm damaged the engine because the water pump isn't pumping as fastNeither does high rev. The only think that shold overheat an engine is a coolant leak, or possible running lean.
Nothing to do with high or low revs.
Not sure I understand this, the faster the piston drops the quicker the air is drawn in with it's matching fuel, it will reach a limit where it falls off again,Questionable, you will have more fuel and air in there to make up for the lack of revs, menaing fewer but bigger explosions.
In winter a 1.2 will not kick the fans in at idle, you have to raise the revs to around 2KEGR also means cooler when at high revs as it's got a cooler burn temp.
Correct but that's not what it says in the video, I disagreed with the videoAt idle there is also far less work for the cooling system to do. But a bit irrelevant as the thermostat controls the cooling, not the waterpump.
Flow not pressure is what's required, when oil can't pass through the tiny passages it's wasted as pressure, the flow is designed to be adequate at idleIf you've ever seen an oil pressure gauge, then the pressure at idle on a hot engine is normally 1 bar or less. Usually the pressure reg controls it at not much above idle. But just because it works, doesn't mean it could be sufficient when the engine it delviering power.
What about the inertia as the pistons change direction, it's pulling something like 5000gs at higher RPMs, yes I don't know the exact figure, I used a similar engine and knocked 2000 gravity's offQuestionable for same reasons above, same power means more torque, means more force on the rods and lower oil pressure.
The reality if far more complex, you are more likely to have higher pressures at low revs since the volumetric efficiency drops as the revs increase (you just cant get the air in quickly enough)
There's more going on here than just the engineAnd I always find petrol engines (not modern eco friendly ones) run better long term when given a bit of abuse.
Not agreeing with the video, just disagreeing with thos comments you made.
