iPhone 3GS with iOS 4 and the phonebook
WAJ
Rotherham
Since upgrading to iOS 4 my blue&me phonebook is empty. I have deleted the old phone book (settings, user data ...... ) and then re-added using the same menu. It tells me it is copying the phonebook, but once completed it is still empty.
This is exactly the same way i added the contacts to the phonebook in the first place. If i select contacts from the settings, user data ...... menu it seems to want me to manually select them on my iPhone. However there doesn't seem to be an option to send a contact over bluetooth.
As anyone else experienced this problem?? I have just thought about re-pairing my phone and will see if that makes any difference.
I can put up with blue&me's many issues, but no phonebook is pretty terminal i can speak the number but thats not a good situation..​
Delete all from your B&M and from your iphone then re-pair
I'm not quite sure what you mean on the iPhone side. Do you mean delete all my contacts and re import them from the sim card??
Hi to all,
the same issue happens to me: before ios4 upgrade all work fine, after upgarde, the phonebook is no more able to be syncronized with the B&M device into my car.
I tried to delete the registered user into B&M with the related phonebook. I also delete the B&M association into the iphone 3g bluetooth tab.
After reassociating B&M and iphone together, the B&M voice tell me to load the phonebook, I agree with that and B&M tell me that the phonebook is loading, but after more than 5 minutes, the contact list into B&M is empty.
I tried with an old iphone 3g with fw 3.2.1 and it work fine, so it is an ios4 issue only.
Anyone can confirm or resolve this?
Thankyou
If you look in the Bluetooth section of your Iphone you will see the connection "Blue & Me",this is all you need to delete before you pair the phone again.
This is what I did..
You are suggesting this way because you know that this solve the issue or it is only your idea?
This solved the problem for my wife with her iphone in her 500
