On a UK 2010 ‘500 the internal door lock lever on the drivers side (RHD)) hits the plastic door panel if I try to manually push the lever inwards to activate the central locking and then does not activate the central locking manually.
If you use the remote key the lever will move inwards and show the red locked indication and lock the doors as designed.
So I am thinking that either the internal handle cable is stretched by a few millimetres or the lock mech attached to the internal handle cable is worn or has slack in it ?
Is there any adjustment I can make to the cable end (pictured) at the internal handle end ?( Bend the metal ferrel or add Packers ?)
Anyone else suffered this issue on their ‘500 please?
- Model
- Fiat 500 Lounge 1.2
- Year
- 2010
