DetergentCandy
Hey y'all! I have a 2017 Jeep Renegade, and since it's essentially a 500X, I'm wondering if maybe I can find some help here.
I've posted about this over on the Jeep Renegade Forums and still not able to find an answer. If you want to read it from the source, it's here.
When getting in to start the vehicle, the push button does the thing and turns on the accessories, but sometimes it fails to actually start. There is no cranking attempt. It just doesn't start, and the battery icon on the dash illuminates. There's no CEL and no codes pending or stored. Sometimes the info display displays "Sound System Unavailable." I'll sit there and push the button over and over and eventually it starts sometimes. But other times I may have to come back in 30 minutes and then it starts on that attempt.
Battery test is good at 13V. And when we test the battery when the engine is running, it's 15V (probably 14.8 but my meter doesn't display decimals so I'm guessing it's rounding up). So I dunno if it's a battery/alternator issue.
I took the battery to Batteries Plus and they tested it overnight and said it's a good battery. However, I'm still going to buy my own load tester today just to confirm myself. I'm not actually sure if Batteries Plus did a load test or just a charge and test.
Battery cables and terminals are tight and in good condition.
We checked and swapped the starter relay thinking maybe that was it, but it's still having the same issues.
We also replaced the brake switch in-case that was preventing the engine from starting, but that didn't fix it. As soon as I attempted to start it after installing the new switch it failed to start. This time, I confirmed my foot remained on the brake. I pressed the brake, and pushed the start button. Accessories turned on, but the engine did not start. I waited a few seconds and pushed the button again, and still no engine start. Then I gave the button a pretty firm and quick tap with the tip of my finger and it started.
Since the push-start button just, doesn't start the engine sometimes, and other times it does, I'm wondering if this could just be a failing ignition button? I'm unsure since the button at least ALWAYS turns the accessories on. It just sometimes doesn't start the engine. Can the button work for the accessories but not work for the ignition? I assume it's just a single button inside without a secondary indent or anything, so I don't know if the button would be able to do one but then fail to do the other when it's all the same single button press.
- Model
- Renegade Deserthawk
- Year
- 2017
- Mileage
- 120000
