Velocemitch
- Joined
- Aug 21, 2011
- Messages
- 105
- Points
- 91
Got an annoying intermittent fault with the wipers on the 93 Selecta.
Sometimes they work sometimes not. Last night I stripped it down checked the feed which seemed to have power, checked the motor which was fine and cleaned quite a bit of greasy gunge off the tracking unit which controls to auto park (probably been applied as new that to lubricate it).
When I put it back together it worked fine for ten minutes then stopped again. It could be a broken wire, but I strongly suspect the auto park or the delayed action unit is causing this. Anybody had issues with these?
Can you get them as spares, or has anybody got one lying around?.
