Re: Re: Re: Re: Re: Interior Question
yeah, the new issue of max power comes out on 10th Oct so the shops will probably get rid of the old ones.
Anyway I'll tell you how to do it.
Take what ever your colouring out of the car.
'Key' the surface, i.e. rub it with 600 grit wet and dry sandpaper (make sure all sandpaper used is wet ,using soapy water), to smooth it and get rid of any silicone cleaners etc.
Dry the panel with a paper towel.
Get some plastic primer, shake it, and apply in smooth even strokes. Thin coats are better, let it dry 10-15 minutes between each coat or it will peel off.
Put about 10 coats on to be safe.
When the finish is deep and even use 1200 grit, wet and dry sandpaper, use soapy water to wet it and smooth it till it's very very smooth. Try not to rub too hard or for too long or you might rub back down to the plastic.
Dry it off and get the paint (I got Halfords to mix me up a can, just give then the code from the boot), shake it, then again apply in smooth even strokes, this does not take as many coats, just get it fully covered, I did about 5 coats of paint.
Don't sand it after this.
Leave the paint to dry for at least an hour, then grab some clear laquer and again apply in smooth even strokes, the more coats of laquer the better the finish will be, I think i did about 8 coats.
Leave it to dry overnight.
Next max power say to sand it with 1200 grit again and then rub T - cut polish restorer into it although I didn't bother because the laquer was shiny and smooth enough already but it's up to you, and that's it.
If anythings not clear or you want to ask a question just send me an email
[email protected]
Gaz
Most important points
apply thin coats
always use the sandpaper wet
try and spray when it's warm, dry and not windy
use PLASTIC primer
You can get the sandpaper from halfords - yellow packets, although I had to try 3 different stores to get the right grit.
Halfords also sell T - cut, plastic primer, clear laquer and they mix paint at some shops.
Get some pics on the forum when you have done it.
