Technical instrument panel lighting??
GRANTDH
hi i have a 2010 fiat florino,the boost regulator sensor is acting up and therefore cuts the turbo out when power is put down too quickly
my dilema is that i have DOE on friday,just wondering does anybody know if the instrument panel have lighting in which you can change the bulbs or if they are LED lighting
i dont want to go stripping it to find out that the bulbs cant be taken out/replaced
regards eoin
Hi m8, Im sorry I cant help you with your problem, but Im sure one of the tech guys will be on later and might be able to advise you.
I believe the clocks are the same as the punto grande so if you post on that section or look on there there might be some info that will help, but i'm sure that the bulbs that are behind the speedo and rev counter are replaceable,and all the warning lights are led and are not.
I know the heater ones are bulbs.
Hope this helps
LUIGI
Daft question I know but they are not working and not just turned ?
