Aha! tyre rubbage!
Is that with the 14" Tempra alloys on? if it is you could do with some 3-5mm spacers ASAP!
The bumper can be repaired either by using 2 pack superglue or a big soldering iron carefully at the back (possibly reinforcing it with offcuts of plastic taken from the bottom lip), then spraying the whole bumper after if its still visible.
I hope you werent laying under her taking pictures (the car that is) when it was only on that jack!
Pictures as promised!
Damage from the outside. You hardly notice it thankfully unless you know where to look!
This is the damage that was done to the tyre (well, not he only damage done, it is like that the whole way round it) - this tyre is now on the rear right hand corner.
SEXY NEW WISHBONE! (and sexy 2nd hand driveshaft á la LouieBee)
This is what I believe the culprit to be. At full lock, the end point of the steering rack touches the innermost rim of the wheel, causing a horrible grinding and scraping noise. That small round circle near slightly above the middle of the picture is the bit that it rubs on. I remember a thread a while back after I had posted about this saying that it was the wheel rubbing on the bottom of the gearbox. I can categorically say that this is NOT the case at all. It is the steering rack end arm that causes it!
However, I also think that the problem could be made worse by the fact that the tyre rubs on the wishbone at full lock too:
As you can see, it is jammed up tight.
That all got sorted. I did however manage to totally bugger up my car jack
I was unwinding it (after finishing all the work!) slightly too vigorously and rocked the car off the jack. Thankfully I was nowhere near it, and it just dropped onto the wheels only. Not really that fussed either! I have the spare jack from my old transit van anyway so just chucked the broken one away.
That's about it really!
