General  inner door panel removal
giorgio2
west yorkshire
ive had my driver side door kicked in by a vandal during the night, is it easy to remove the inner door panel so that i can try and push out the rather large dent.
thanks
Quite easy to do, pop off any trims such as the exterior mirror trim which sits over the edge of the panel, then just have a good look around the panel and you will see the various screws and bolts holding the panel, the door pull etc. take them all out and then pull the panel away from the door, this will release the trim clips hidden behind the panel (do this carefully just in case you have missed a screw or bolt). Lift the panel up to unhook it from the top (winding the window down helps here), unclip the electric window connections and you are there. Refitting is the reverse, just make sure all the trim clips are back in their slots on the back of the door card as they have a habit of staying in the door sometimes. Good luck:)
