G GABRIEL MASHA New member Joined May 5, 2025 Messages 3 Points 1 Location LIMPOPO May 5, 2025 #1 What might cause injectors to not get enough power supply from the battery? Model fiat Punto evo Year 2014
B bugsymike Patron member Joined Jul 2, 2022 Messages 13,702 Points 5,434 Location Torbay May 6, 2025 #2 GABRIEL MASHA said: What might cause injectors to not get enough power supply from the battery? Click to expand... Signal from ECU issue? Poor earthing?
OP OP G GABRIEL MASHA New member Joined May 5, 2025 Messages 3 Points 1 Location LIMPOPO May 6, 2025 #3 bugsymike said: Signal from ECU issue? Poor earthing? Click to expand... How can I fix the problem?
B bugsymike Patron member Joined Jul 2, 2022 Messages 13,702 Points 5,434 Location Torbay May 6, 2025 #4 GABRIEL MASHA said: How can I fix the problem? Click to expand... Check the wiring.
OP OP G GABRIEL MASHA New member Joined May 5, 2025 Messages 3 Points 1 Location LIMPOPO May 6, 2025 #5 bugsymike said: Check the wiring. Click to expand... Thank you
