hi can any of you guys help me.ive a 1.6 bravo sx on a p reg.the problem i have is that no 1 cylinder is not firing.the injecto light is on on the dash.its had new plugs and leads.i took sparkplug out and got a strong spark.is it possible the injector is blocked and would this make the light come on.ive tested the injectors at the plug and all show the same ohms.tested coil ohms ok but wouldnt have spark if that was shot.ohms on crank sensor fine too also had new lamba sensor.when running and take off lead makes no difference to engine where as 2 3 4 do.can i test to see if spraying in fuel while in engine.cheers
