Dan
My Fiat Bravo 1.4 sx has always had the fuel injector light come on at some point. I tried cleaner fluid in the tank without any luck.
Recently my car began squeaking, upon investigation I noticed the engine oil was low, so I topped it up and the squeaking stopped for a while. I've also noticed another problem recently, overheating.
I've checked the fan, fuses and cables, which all seem to work. Possibly the temperature sensitive fan switch may be faulty as it only seems to activate in boiling water just from the kettle (i removed it and used electrical testers).
After speaking to a mechanic, I removed the thermostat, which only seems to make the problem worse. The fan still won't activate when temp is 75%.
Any help would be much appreciated
