Hi, hazards switch off and on ok and when central locking is locked and opened the indicators flash as they should and turn off. I have disconnected the battery and reset but still do not cancel when indicator stalk is back in middle position.
As they switch off via hazards and central locking I don't think I have a grounding problem.
I'm assuming its an issue with the BCM.
The issue is with all the indicator lights, front side and rear.
This happens whether I have indicated left or right.
If I indicate left and return to middle they carry on blinking left, if I then indicate right then return to middle the car continues to indicate right.
Any ideas?
Thank you
Any ideas?
Thank you
