Technical Indicator fuse
Alvin Meister
I have 1.9TD K reg Tipo and the indicators have stopped working. The hazards work fine.
No manual came with the car - can anyone tell me which fuse is for the indicators, so I can check it?
It is the one with the left/right arrows... they don't have numbers - just pictures - to make it easy - when you dont have a manual... ;)
It is a 7.5A one, next to the 25A one for the radiator fan...
If the fuses are okay check the relay (usually large blue one to the bottom of the fusebox).
Also check the operation of the indicator stalk, it should make a clean click when you switch it, chances are the contacts will be crudded up and need cleaning.
