Communicator
Prominent member
- Joined
- Aug 3, 2019
- Messages
- 3,503
- Points
- 957
I hope that you temporary bolt was not inserted too far causing damage.I didn't know what a wax stat was but having read up on it I wouldn't have thought so either.
I had a thought lastnight though and hope this will be the problem. Directly above the solenoid box is a bleed nipple on the fuel pump. This was in the way of the multi tool so we temporarily swapped it for a short bolt to give us more room and I reckon it's drawn in some air. This seems to be the only thing we did that no one else has mentioned doing and they've had successful bypasses.
@bugsymike I appreciate your explanation on how to bleed the injectors but I'm not confident I've done it 100% correctly and wonder whether it also needs bleeding from the filter and the nipple we removed. I have a mobile mechanic coming this afternoon to bleed the system so I will report back whether it makes a difference.
As consolation, in my younger days I had a diesel Land Rover. I could bleed from two nipples on the pump with the engine running on level ground, to no avail, because as soon as the vehicle was on a slight tilt the engine stopped. Another small bubble of air out, and all was then OK.
