Ignition problem
Ignition problem
C
Chris Mitchell
Can anyone help me. 1600 sx is only running on 3 cylinders. I have checked the plugs and leads they are all working fine (checked by swapping them over) but there is no spark to one of the leads.
The leads appear to be connected to a black box mounted to the engine. I'm assuming this has something to do with the electronic full injection ?
Ignition
I had the problem on my 1.8ELX. You have to change the ignition cable for that cylinder.
Good Luck.
ignition coil
it sounds like your ignition coil has packed up, thats the black box with an aluminium cover on it!! it should have the part numbers BAE 920 on it somewhere. I know this because we make them for the Bravo and when they first came out they had a internal fault!! so my guess is a new coil. not sure how expensive but a breaker should be a better option if FIAT charge the earth.
W
922
wakka
W
T
1
804
Joseph
J
O
3
570
K
V
5
747
Laurie
L
I
2
1K
Dark Lurker
