Technical  Ignition mystery
lucienlucienlucien
My 92 Panda 750 got broken into recently and I've fixed everything but the ignition barrel/switch which had been pulled apart. Weirdly they must've taken the switch with them or chucked it into the hedgerow, I've got a replacement switch but it won't fit and I suspect I'm missing another bit. I'd be really grateful if someone could look at the photo I've attached of where the switch locates and identify A. if I'm missing a bit and B. if said bit is replaceable or whether I'll need to swap out the entire column? :confused:
Lucien
Ok pic of bottom of switch it should have a bevel gear to locate with other gear which then turns switch you may have an newer after market barrel fitted or old style switch
thanks for your replies i think i must've lost the second bevel gear - perhaps they chucked it somewhere as it's definitely not anywhere in the car. Is there a way of getting hold of these bits? Or do I have to get a complete ignition assembly?
You may be lucky and get just that part from a forum member who has a broken or replaced lock and switch mech.we may have one I will find out tonight.
Steve
