wilse
- Joined
- Oct 8, 2012
- Messages
- 6
- Points
- 1
Hi all,
Despite being an avid fan/user of this forum for years I’ve finally decided to register to ask for help. I’ve exhausted as much as possible the current forum links regarding a problem I’ve got with my 2000 Seicento Sporting but have finally accepted ‘defeat’ and need some assistance. The problem I’ve got is intriguing to say the least. It starts first time every time but after approximately 15 minutes it completely dies, no shudder, no misfire, nothing, just stops. After happening twice (the second time being right outside my house, had to push it onto the drive!) I called a ‘breakdown’ mechanic who said it’s either the crankshaft sensor, HT leads and plugs or the ECU. Having changed the crankshaft sensor 3+ months earlier without problems he ruled this out. I then changed the leads and plugs but again after 15 minutes or so the car just dies. I read on numerous threads that it could be the coils so happily replaced these last Saturday. I anxiously sat on the edge of the drive clock watching while it ‘purred’ away, having fired up first time after replacing the coils. Yet again, 15 minutes in and it died. This time however it allowed me to instantly restart the engine but died again after 9 minutes at which point it wouldn’t start again. The fan kicked in a few times so I don’t think it’s anything to do with overheating. As I say, it starts first time and runs normally without any spluttering or misfire and then just goes all stealth on me. I’m beginning to suspect it might be a bug in the ECU but would greatly appreciate your thoughts before forking out for a new one to be fitted/programmed.
Thanks in advance for your feedback.
Regards,
Wilse
Regards,
Wilse
