J jim cooper Patron member Joined Jan 1, 2007 Messages 752 Points 268 Location Bangor, County Down Mar 14, 2019 #1 Can anyone tell me how to remove the low tension wire from an ignition coil on a Stilo 1.4? I don't understand how the little yellow tab works and have already broken the top off one coil.
Yellow Peril Patron member Joined Apr 20, 2005 Messages 2,748 Points 553 Location South East Mar 14, 2019 #2 Jim - you pinch the little yellow tabs together, then pull. See this guide (the section headed 'Disconnect the ignition lead') - there's a photo: https://www.fiatforum.com/stilo-guides/109914-change-your-spark-plugs-gars3.html#content_start
OP OP J jim cooper Patron member Joined Jan 1, 2007 Messages 752 Points 268 Location Bangor, County Down Mar 14, 2019 #3 Many thanks for your help.
