I NEED HELP
I NEED HELP
DIM
My Brava 1.4 also has problems starting in the morning... I turn the key and wait for the pump noise to stop and then start it but it won't turn, it's like there isn't enough petrol to make it going (it kind chokes and turns off) so I try again and as soon as it starts to turn I step on the gas pedal and it starts ok, it idles a bit roughly if I remove my foot until it's beginning to get warm, after that everything is ok...
What could be the problem?
When was last service done and what ?
Sounds like plugs, leads, or fuel filter .....
Members Site ---------My Site
hello , maybe is the fuel pomp , filter , rele i dont know . the last service done in november , maybe the better solution is ECU examination,, really thanks
If the service has done plugs, petrol filter, the only thing that comes in mind is a weak fuel pump. Best would be to measure the pump pressure.
ok , thank u , i will see first that , thank u , i have close Appoitment with Garage
3
1K
Tommy K
T
T
5
688
K
1
685
Dark Lurker
A
5
671
M
