HP Pavilion "BOOTMGR is missing"
wilmslow, cheshire
ok, my step son bought a hp pavilion lappy that shoudl have had vista on it but it had been attempted upgrade to win7, which worked ok but no sound from it
so he wanted it back to vista
have got a vista disk, so tried to reinstall, it stopped at about 26% of expanding files, so I restarted and now getting
BOOTMGR is missing
ctrl+alt+del to restart
which just loops back if restarted
can I fix this, even if it means taking the hard drive into a caddy to access from another computer? other online guides say that the lappy should boot into the vista cd but it wont in this case
anyone help with any info?
So the laptop won't boot from the Vista disc, you've check the settings in the BIOS and there is no option to do that?
If that's the case (which seems unlikely), you could try making a bootable USB Vista installer (assuming the laptop can boot from USB). If it can only boot from HDD then yes, you'll need to load Vista from another machine.
It might be too late now since you've tried a reinstall. This has happened to me several times before with Windows 7.
If your computer has a built in recovery thing try that, normally F10 on start up. If not boot the Vista disc but somewhere before installation you should be given a recovery option or a repair menu.
If you come across this option click on the recovering using Command Prompt and then type the following, hitting the enter return key between each line.
bootrec /FixMbr [enter]
bootrec /FixBoot [enter]
bootrec /RebuildBcd [enter]
