death_paladin9
- Joined
- Feb 2, 2006
- Messages
- 136
- Points
- 47
My engine has become very oily (front side). I think upper and lower camshaft gaskets are leaking. How must it be washed ? Hot water ?
Cheers
Cheers
Cheers
Cheers
Oh and replace the camcover gaskets!
Thanks guys.
By doing that the camshaft must be taken off. It requres much of a work and I don't have the knowlede nor equipment, to set the timing belt. If I go to mechanics, they will rip me off + there is no garantee it will not leak again. Mechanic one replaced the upper cam gasket and guess what happened.. in 5 days it was leaking on the same place. It's cheaper to fill up the oil from time to time I think![]()
Thanks guys.
Does it? Removing the camcover on the 2.0 16v only requires the breather tube to be removed.
Lower cam gasket? You mean the head gasket or does yours have 2 separate cam covers?
