Technical How to rewire radio 2002 ducato
If it is wired via an ISO connector then it is. There should be a yellow wire which is the battery feed and ensures the radio does not lose its programming when the ignition is switched off and a red wire which is the ignition feed. Cut the red wire and insulate the end coming from the vehicle. Connect the other end to the yellow wire. [sometimes the yellow wire is orange].
Many thanks for that, i shall have a play when it warms up.:worship:
