Technical How to replace cylinder head gasket at Fiat UNO 1.4 1995
Amit1
Hello all,
I am looking after instructions how to replace head gasket in my UNO 1.4 1995.
Amit
Don't think the 1.4 fire was about in 1995. Sohc rings a bell. I have seen an Uno with 1.4 Tjet that lewey fitted. I made the mistake of getting in for a ride round Oulton park.
Hi, if you can get a Haynes workshop Manual ( 0923 ) it covers the 1.4 i.E Uno. Which is what I assume, is the model you have?
It will explain how to remove the cylinder head, and have information on what torque the bolts should be etc..
It's fairly comprehensive, but as anyone will tell you in the UK these manuals always miss something out. So see it more as a guide, failing that it might be worth looking on eBay for a genuine Fiat manual that the Fiat dealers would use.
Hope that helps, an that you can your Uno fixed ��
