Technical How to remove the evaporator from Bravo?
Dubai
Is there any trick to get an evaporator out or I need to remove complete dashboard/console in order to access it ?!
Wanted to refill the gas for A/C, but system is losing preasure somewhere...
Guys did check compressor, hoses, all the connections around and all seem to be fine, no signs of leakage... The only thing left to be checked is evaporator, I do believe it's one of seal gaskets, however I still need to get there :)
Vehicle is Bravo HGT 155i MK2, 08/1999.
I have the same problem and same question?
Anybody know something about this?
Mate, I still didn't finish it, lack of time at the moment, but I'm on a half way let's say...
Story goes like this - you have to remove everything :D
I am not yet sure about steering wheel, but will let u soon...
Take a look to these docs, good to start with:
http://www.bravo-guide.co.uk/photogal/guidepics/dashbulb .pdf
http://www.bravo-guide.co.uk/photogal/guidepics/centerdashpart.pdf
Look at the 840-860 pages of Bravo service manual, Vol3.
If u don't have it, here they are:
[ame]http://rapidshare.com/files/37024868/Fiat_Bravo-Brava_Service_Manual_Vol1.pdf[/ame]
[ame]http://rapidshare.com/files/37029454/Fiat_Bravo-Brava_Service_Manual_Vol2.pdf[/ame]
[ame]http://rapidshare.com/files/37049277/Fiat_Bravo-Brava_Service_Manual_Vol3.pdf[/ame]
Take care,
D...
Does anybody know what to do next ?! :)
you must remove the heater tubes on the motor compartment and pull the box out
