Technical How to remove locking wheel nuts
allan jenkins
South wales
Guy.
I have 16" alloy wheels on my Mrs Bravo and I have lost the locking nuts key..
Does any one know how I can remove them (without the key)
Drill them out or, you can buy tools to do it. Tools cost about, if not more than a replacement key from fiat. There are several types so you'd be best driving it to a dealer.
Ben
Main dealer has a master key/tool set. Best option :)
Call AA/RAC and be very polite, they have a dynomec tool to remove them, has about 60% success rate at loosening the bolt off. ( don't ring up at midnight when it's raining )
Kwik fit can also do it but only if you have new bolts to replace the ones removed.
Any small garage with enthusiasm should be able to sort it.
Do you still have the box that the locking key came in? If so it should have a 3 digit number in there which is the number of the key. Won't need pics if you have that
The linked tool is no use whatsoever for removing a locking wheel nut (bolt) without the key. All it does is heat the fastener up. I guess you did not read the original post or misunderstand what the tool does.
Also a bargain at £600....
Robert G8RPI.
why wouldnt it help? it will heat it up so much you can probably unscrew that bolt with pliers
you could try a gator grip socket as these fit to any size or shape or size of nut and can undo even rounded off nuts check out ebay for pictures of and price of these sockets
Apart from the fact that the bolt isn't seized and has a rotating outer sleeve to stop it being turned with pliers, so heat of any sort won't help much, there is so much heat sinking on a wheel bolt (alloy wheel, brake disk, hub) little short of a "gas-axe" will heat it up enough to make any difference. Additionally, as the tool is an induction heater the alloy wheel in close proximity to the coil will absorb a lot of the energy.
Indeed that tool is not designed for removing locking wheel nuts at all, it's for heating rusted in nuts & bolts. Yer man Edd China was using one on Wheeler Dealers episode I was watching the other night, removing a said rusted in stud bolt/nut on an exhaust manifold.
Apart from the fact that the bolt has a rotating outer sleeve to stop it being turned with pliers
or does it..?? :confused:
Allan has yet to confirm this.. ( what style of locking bolt)
:idea:how about - freeze bolt head with Liquid Nitrogen, then just SNAP the Head off,
remove wheel,
unwind stub,
fit new bolt..
I'd still wait for the correct tool;)
I have the said tool and defenatley no good for removing wheel bolts. If you got one that's murder tight the best thing to do is get the key put it on the bolt and fit a long reach impact socket on it then grip the socket with a pair of mole grips and give the socket a good few hits with a big hammer. The shock helps it loosen up, got loads out this way. Otherwise you just brake the locking key
Five years ago.
With 5 Kg hammer took 30 seconds for every wheel
How do you find the induction heater generally? Is it useful and if so what is it best for?
Robert G8RPI.
