How to remove ignition switch module for a 2003 Ducato 2.0 JTD (244)
FamaMarah
Hello All,
My Ducato has been stalling frequently in traffic. Internet research points to several potential causes including egr, fuel filter, throttle position sensor, ignition switch. After a process Of élimination and thé récent manifestation Of other problems such as flickering dashboard lights and engine failing to shut off when ignition is switched to thé "off" position, i am betting heavily on thé ignition switch being faulty.
Can someone be so kind as to provide accurate instructions, with pictures if possible, on how to remove thé ignition switch for a 2003 Ducato 2.0 JTD? Other how to guides on thé internet have not been helpful. Model specific variations sometimes make generic guides misleading or even harmful.
I am stuck and need to get thé Ducato moving asap. I Can do away with pictures in the interests Of early résponses to this post.
Thanks,
Fama
OK so i removed thé ignition switch without much hassle. It is marked "Fiat Lancia". It bears thé following numbers in two rows:
First row - 42 2. Note thé space.
Second row- 05139.
Question : Are Fiat ducato ignition switches interchangeable with Fiat Lancia switches? If they are incompatible, that should explain thé stalling.
How can one visually identify a faulty ignition switch once taken out? How can i tell thé problem is not with thé cylinder into which thé switch solides?
What is/are thé approved part Number(s) for a 2003 ducato ignition switch?
