Technical How to remove doorcard on 3dr stilo
leechartlon
hi do's anyone no how to remove the doorcard on a 3dr stilo i took all the bolts out and tryed to pull it away from the door but couldnt get corner bit of where tweeter speaker is and couldnt lift it over the top bit can anyone help me
The screw-in fixings are only part of story, the card is also held in place with white nylon clips that are locked into the card and are a press fit into holes in the door. The top of the card is a press fit into the space between the door and window. When you do remove it, remember to disconnect the wiring for the red alarm LED.
