General  How to lock without battery?
trumee
I am planning to disconnect the battery since i dont use the car very much. Unfortunately, i have noticed that i am unable to lock the car from outside with the battery disconnected.
Seems silly, but surely there must be some other way to lock the car without a battery. Any ideas?
It's on the rear of each door next to the latch. Look at the open driver's door around the latch. You will see that there are only three fixings. The fourth is the lock. To lock it, put the ignition key in, turn it clockwise until it clicks then shut the door.
I could be wrong but I think you will need to connect the battery to lock the boot.
If the door needs to be open to lock it, how do you unlock it?
Yeah this worked!. Thanks for the tip.
