Styling how to get side mirrors off of L reg.???
the wing mirrors?
Theres a plastic cover on the inside - take that off. Theres a ring with a few slots cut out. Get a small flatblade screwdriver and hammer and tap them loose (anticlockwise - as if undoing a nut - which is what it is). You should be able to unscrew. Then they just pull out :)
Mine must have been off before as it was loose.
:rolleyes: You are supposed to buy a special FIAT tool...
:eek: Don't forget to open the window and support the mirror from the outside as you whack it, and remove the bolt – ;) you don’t want 7 years bad luck.
:p There may be some rust to treat when you get the mirror off.
Regards All,
