Locate rubber boot and remove exposing wiring and rear of bulb which is held in place by a spring clip.
Remove wiring connector block at rear of bulb. Examine spring clip and you will see that it has two small curlicues, press curlicues together and move rearward at the same time to release bulb noting it's position in the holder.
Reverse procedure to install new bulb.
Peat
