how much ?
how much ?
dukes brok
hello i need some advic when topping up engine oil on the bravo, there are no indications given were the maxium or minimum marks are so were do all the bravo owners top the oil up 2, n how often>
There is a mark, there is a picture of it in the handbook.
Top it up when needed, check it every couple of weeks unless you are doing daft milage.
yeh,mate im having the same prob any1 kindly post a pic, dave.
You both need to buy a new dipstick..
Should be pretty cheap from a Fiat dealer
ive got a dipstick, its not bone dry im asking were are the markings
At the end of the dipstick there should be a flat spot roughly half an inch, your oil level should measure within the flat spot, Seems you dont have any knowledge of an engine so buy yourself a haynes manual, there cheap on ebay
My dipstick is a long coil and at the end its just a flat bit with markings on..
so the end bit, where it curves in is the maxium and minimum then cos i got same prob dan,
